2024-05-08 10:56 PM - edited 2024-05-08 11:16 PM
I need to externally generate image for my project. as touchGFX documentation mentioned that I can do that using imageconvert.out. when I followed the instructions of how I should use the engine (https://support.touchgfx.com/docs/development/ui-development/working-with-touchgfx/using-ides-with-touchgfx.). it didn't work as it supposed to be. any ideas of how I should use it properly?
2024-09-02 7:08 AM
Hello @zouzou96 ,
Have you been able to solve your problem?
If so, I invite you to select the most helpful comment as "best answer".
