Touchgfx (+VIDEO) button blink but fuzzy interface changes
- September 20, 2023
- 4 replies
- 1772 views
Hello friends, I have a problem with a resistive touchscreen interface.
The device and the touch perform very well, I managed to combine an algorithm that does not create jumps and considers a neighborhood of the touch to have a very stable value of the outgoing coordinates, but I have a problem with the touchgfx. Even if you make contact (see the attached video), the button blinks but the page does not change. I believe there is a threshold for the temporal release of the button, otherwise the touchgfx does not consider the button touched voluntarily.
All of this is hard for me to control. I wanted to know if you had any advice on the matter, I can't find similar problems, usually everyone uses capacitive ones with external controller.
Thank you.
