TouchGFX Designer v4.23.2 not generating IDE project files
PFlor.2
Senior
The last custom board project I did, the ST contact told me to start with TouchGFX designer (4.20.0) and generate the project from there.  Then I was able to import the existing project into STM32CubeIDE.  However the new version 4.23.2 does not seem to generate the .cproject and .project files in order to import the existing project into STM32CubeIDE.  Is there something I'm missing?
PFlor.2
Senior
I found them under a STM32CubeIDE subdirectory
2 REPLIES 2
PFlor.2
Senior
Hello @PFlor.2,
Good to hear you have found the project. Could you please select your comment as 'Accepted Solution'?
Best regards,
Mohammad MORADI
