TouchGFX designer: the remote server returned an error: (403) Forbidden
Ajoub.1
TouchGFX Designer doesn't show me any online application or template (just the Simulation with the black UI template).
I'm using version 4.16.0 and it shows me the following error :
Package server at HTTP://packages.touchgfx.com/V2/packages.json.zip can not be reached No online packages can be found.
You can continue working, but only already installed packages are available.
the remote server returned an error: (403) Forbidden.
I try also the newest version 4.17.0 and it shows me, "the application is not connected to the internet"
hello, thank you for your answer, I fix the problem, I didn't know how, I just open the software and it work
Imen.D
Hello @Ajoub.1​ ,
Can yo please try the temporary fix shared in this post ?
Imen
Imen
