Touchgfx Designer is not opening in the computer.
MPath.4
 last time also this problem was occured so I installed it again after that it run for some days now again the problem has occured.
 When I open Touchgfx one msg come
Sorry - something unexpected has happened which caused an error to occur in the Designer.
For more information, see the log file located at: C:\Users\Kaushal\AppData\Roaming\TouchGFX-4.21.3\TouchGFXDesigner.log
Please someone help to give the solution of it.
25 REPLIES 25
MPath.4
Yoann KLEIN
This file looks empty or erroneous, did you modify it before sharing it ?
/Yoann
Yoann KLEIN
MPath.4
No I didn't I send it to you once again
MPath.4
MPath.4
This is another one.
posted a file.
MPath.4
It happened yesterday in the older version also when I generated code in stm32cubemx
Yoann KLEIN
When you open this file in a text editor, what do you see ?
/Yoann
Yoann KLEIN
Actually the touchgfx doesn't open so I can't open any of these files.
But I didn't modify it because I can't do it.
I mean, when you right click on it and open it with Notepad.
/Yoann
Yoann KLEIN
It is showing nul in last 3 to 4 projects just check this one
