STM32H7 JPEG Encoding does not work with DMA
2023-03-08 3:11 PM
I'm trying to run the JPEG_EncodingFromFLASH_DMA example and the HAL_JPEG_GetDataCallback & HAL_JPEG_DataReadyCallback never executed.
If I try the polling method, the process is successful.
I've disabled the D-Cache & I-Cache.
JPEG
STM32H7 series
2023-03-15 8:20 AM
@MCiau.1 Hi again,
Could you provide more details where it crashes? Status of JPEG registers after HAL_JPEG_Init(); would help as well.
For a while I thought of another issue. but this example is working fine for me on Discovery H747.
Thank you for your contribution.
Firas
2023-03-09 3:38 PM
Hello @MCiau.1 and welcome to ST Community
Could you specify the STM32H7 board used? Disco/EVAL?
2023-03-10 8:20 AM
Hello @F.Belaid , thank you for your help.
I'm using the Portenta H7 board which is based on the STM32H747XI MCU.
Do you have any suggestions on how to get JPEG to work with DMA Mode?
Regards!
2023-03-13 1:43 AM
Hello @MCiau.1,
Issue tracked internally. I will get back to you as soon as possible.
2023-03-15 8:20 AM
@MCiau.1 Hi again,
Firas
