STM32F429 discovery board
‎2020-02-05 7:18 AM
Has anyone been able to create a working project with CubeMX 5.5 and TouchGFX 4.13?
- Labels:
STM32F4 Series
TouchGFX
‎2020-03-31 8:16 AM
Did you check the Application template from the designer?
There's a new version 3 up that supports CubeMX 5.5!
/Martin
‎2020-03-31 8:16 AM
/Martin
‎2020-03-31 10:08 PM
I did at first, but it wasn't there. Now I see that there is a new template version there. Thanks for posting this, and I will give it a try.
Matej
‎2020-04-15 11:18 AM
I have tried it out and if you are using the template screen transitions are not working on device (project built with cube IDE), but are working fine in the TouchGFX Simulator. Is there something that needs to be enabled?
Thx Matej
