STM32F429 Discovery + ADC + DMA + TIM2 + TFT-LCD problem
‎2019-11-25 3:58 AM
Hello, I am new to STM32. I'm using ST32F429 Discovery board and I'm tring to read audio samples from ADC1 (PA5)+DMA, which is trigged by TIM2, and visualize the data on the LCD screen using BSP driver. I am using STM32CUBEIDE to generate source codes. I'm able to toggle the green LED every time the adc conversions (10 data) is completed. However, when I initialize the LCD using BSP_LCD functions, the led is not blinking.
Please help me solving this problem.
Thank you
- Labels:
GPIO-EXTI
LCD-LTDC
STM32F4 Series
‎2019-11-25 4:55 AM
Use debugger to find out, if it ends up up in error handler, or gets stuck in an ISR forever, or loops in an endless loop.
‎2019-12-02 5:28 AM
Thanks you for you suggestion. I am sure what causes the problem, but I found that my settings on PPLSAIN (x50), PPLSAIR (/2) and PLLCDCLK divisor (/2) were different from the values in stm32f429i_discovery_lcd.c. After changing these values to PPLSAIN=x192, PLLSAIR=/4, and PLLLCDCLK divisor=/8, the LCD is working again.
