stm32f103 and winstar TFT display problem
rafal_kula
Posted on March 09, 2016 at 14:24
Hi all,
I have problem with displaying any data at WF57STIACDNN0 TFT display. This is a TFT display with ST7511U driver. In my SW driver I successfully pass the display initialization procedure - I see some randomize pixels set, but I am NOT able to display any data by write RAM command - 0x2C (ST75_WRAM).
First my goal is to clear whole display and set each pixel on the screen. For communication I am using 4 line (A0 + SPI).
In the past I only wrote some drivers for easy ALPHA display so I have no any knowledge about graphic display.
Below I will put by initialize function and function where I would like to clear whole display area.
static
void
display_init()
CS_ENABLE
spi_write_command(
ST75_SWRESET
spi_write_data(
0xa5
//Power
Control
spi_write_command(
ST75_PWRCTL
spi_write_data(
0x8f
//booster
setting
''10''
-2
spi_write_data(
0x04
//SAMPSet
''100''
spi_write_data(
0xa5
//WARNING
in
spec
is
0x0a5
spi_write_data(
0xa5
//Electronic
Volume
Set
1
spi_write_command(
ST75_EVSET1
spi_write_data(
0x36
//VCOM
spi_write_data(
0x0b
//VGHREG
spi_write_data(
0x0b
//VGLREG
spi_write_data(
0xa5
//Display
area
spi_write_command(
0x31
spi_write_data(
0x00
spi_write_data(
0xEF
//0
239
240
spi_write_data(
0x02
spi_write_data(
0x7F
//Display
Set
2:
Set
source
and
gate
ON/OFF
timing
spi_write_command(
ST75_DISSET2
spi_write_data(
0x07
spi_write_data(
0x2c
spi_write_data(
0x09
spi_write_data(
0x2a
//Electronic
Volume
Set
2
spi_write_command(
ST75_EVSET2
spi_write_data(
0x09
//GVDD[4:0]
spi_write_data(
0x17
//GVCL[4:0]
spi_write_data(
0xa5
spi_write_data(
0xa5
//Gamma
Set
4bpp
Positive
1
spi_write_command(
ST75_GAMSET4P1
spi_write_data(
0x00
spi_write_data(
0x16
spi_write_data(
0x1B
spi_write_data(
0x1C
spi_write_command(
ST75_GAMSET4P2
spi_write_data(
0x1E
spi_write_data(
0x1F
spi_write_data(
0x20
spi_write_data(
0x21
spi_write_command(
ST75_GAMSET4P3
spi_write_data(
0x23
spi_write_data(
0x24
spi_write_data(
0x26
spi_write_data(
0x28
spi_write_command(
ST75_GAMSET4P4
spi_write_data(
0x2B
spi_write_data(
0x2F
spi_write_data(
0x34
spi_write_data(
0x3f
//Gamma
Set
4bpp
Negative
1
spi_write_command(
ST75_GAMSET4N1
spi_write_data(
0x00
spi_write_data(
0x16
spi_write_data(
0x1B
spi_write_data(
0x1C
spi_write_command(
ST75_GAMSET4N2
spi_write_data(
0x1E
spi_write_data(
0x1F
spi_write_data(
0x20
spi_write_data(
0x21
spi_write_command(
ST75_GAMSET4N3
spi_write_data(
0x23
spi_write_data(
0x24
spi_write_data(
0x26
spi_write_data(
0x28
spi_write_command(
ST75_GAMSET4N4
spi_write_data(
0x2B
spi_write_data(
0x2F
spi_write_data(
0x34
spi_write_data(
0x3F
//Sleep
Out
spi_write_command(
ST75_SLPOUT
spi_write_data(
0xA5
&sharpif
1
is
set
to
ZERO
by
default
//Memory
Address
Control:
Set
about
display
data
RAM.
Select
address
incremental
direction:
MV
0
(Incremental
column
addr.)
Display
data
RAM
page
address:
MY
0
(Normal)
Display
data
RAM
column
address
MX
0
(Normal)
spi_write_command(
ST75_MADCTL
//sleep_ms(2);
//sleep
is
required
by
specyficatrion
ST7511U
spi_write_data(
0x00
//in
spec
is
set
to
0x01
[F57STIACDNN0]
spi_write_data(
0xA5
spi_write_data(
0xA5
spi_write_data(
0xA5
&sharpendif
//BPP
Select:
Set
data
format
(bit
per
pixel)
BPP
spi_write_command(
ST75_BPPSEL
spi_write_data(
0x00
1bpp,
(2
gray
scale)
1
bit
per
pixel
spi_write_data(
0xA5
spi_write_data(
0xA5
spi_write_data(
0xA5
spi_write_command(
0x25
//page
address
set
spi_write_data(
0x00
//start
0
spi_write_data(
0x29
//end
41
spi_write_data(
0x00
spi_write_data(
0xa5
spi_write_command(
0x26
//Collumn
address
set
spi_write_data(
0x00
//start
0
spi_write_data(
0x00
spi_write_data(
0x01
//end
479
spi_write_data(
0xdf
//Display
on
spi_write_command(
ST75_DISON
spi_write_data(
0xA5
asm
''NOP''
CS_DISABLE
And hear the function when I would like to clear whole display area:
void
ST75_display_clr()
UInt16_t
i,j;
//640/320
ST75_set_window(
0
639
0
320
spi_write_command(
ST75_WRRAM
for
(i=
0
; i<
30
; i++) {
for
(j =
0
; j<
639
; j++) {
spi_write_data(
0x00
//640/320
static
void
ST75_set_window(
UInt16_t
s_x,
UInt16_t
e_x,
UInt16_t
s_y,
UInt16_t
e_y)
//x,
max
640
//CSA:
Set
column
START
addres
spi_write_command(
ST75_CASET
spi_write_data(s_x >>
8
spi_write_data((
UInt8_t
)s_x);
//max
//CEA:
Set
column
END
address
spi_write_data(e_x >>
8
//end
479
spi_write_data((
UInt8_t
)e_x);
//y,
max
160
spi_write_command(
ST75_PASET
//PSA:
Set
page
START
address
spi_write_data(s_y);
//x
max
//PEA:
Set
page
END
address
spi_write_data(e_y);
//DEFAULT
//FrmA:
Set
frame
address
00
spi_write_data(
0x00
//DEFAULT
spi_write_data(
0xA5
Br,
ToR
#tf #winstar #display #lcd #stm32
0 REPLIES 0
