STM32CubieIDE - TouchGFX - STM32F469I-DISCO - Tutorial 2 -white noise on screen when adding an image.
Fab_0815
I am working with the new CubeIDE and touchGFX. I try to do the Tutorial 2 (https://touchgfx.zendesk.com/hc/en-us/articles/205443722-Step-1-Setting-a-background-Image). Always when i insert the given images to my GUI, the screen on my board remains in static white noise.
When i build the project with the given tools (just a black background and blue buttons) everything is working fine.
Du you habe any suggestions what am i doing wrong?!
Martin KJELDSEN
Chief III
I think you may not have programmed your QSPI flash. That's why box is working fine. If you try to use a smaller image you should see noise confined to that area - That would confirm what i just said.
/Martin
Thanks for the reply!
I was able to solve the issue with installing the new TouchGFX Designer (v. 4.12.3) and the new STMCubeIDE (v. 1.10.0) .
That's great, @Fab_0815​ !
