Resistive touch screen calibration problem: setCalibrationMatrix translating points incorrectly
‎2020-04-15 1:49 PM
Hey,
I'm working on custom board project with display size 800x480px and resistive touch screen. I have issue with using setCalibrationMatrix. Below is code snippet from my STM32TouchController.cpp file. In initalization, calibration matrix i set by calling calib.setCalibrationMatrix(reference_points, adc_points). I determined adc_points using the debugger by clicking on reference_points drawn on the screen. adc_points are raw values from AD converter the same goes for x_val and y_val in sampleTouch routine. After the calibration matrix is set as seen below the values in touchgfx engine are translated incorrectly. To be precise y coordinate is offseted by +160. Here are three examples for touched and translated points:
- pressed reference point drawn on screen in position
x: 40 y: 40 is translated to x: 42 y: 203 (raw adc values: x: 427 y: 804)
- x: 760 y: 40 -----------------> x: 762 y: 202 (raw adc values: x: 3678 y: 844)
- x: 760 y: 440 -----------------> x: 762 y: 603 (raw adc values: x: 3677 y: 3489)
So my question is am I doing something wrong or is something wrong with mathematics in touchgfx engine ?
TouchCalibration calib;
touchgfx::Point reference_points[3] =
{ 40, 40 },
{ 760, 40 },
{ 760, 440 }
touchgfx::Point adc_points[3]=
{ 424, 820},
{ 3675, 861},
{ 3678, 3502},
void STM32TouchController::init()
* Initialize touch controller and driver
calib.setCalibrationMatrix(reference_points, adc_points);
bool STM32TouchController::sampleTouch(int32_t& x, int32_t& y)
* By default sampleTouch returns false,
* return true if a touch has been detected, otherwise false.
* Coordinates are passed to the caller by reference by x and y.
* This function is called by th
* e TouchGFX framework.
* By default sampleTouch is called every tick, this can be adjusted by HAL::setTouchSampleRate(int8_t);
osDelay(debounce_time);
if(touch_detect()){
int32_t x_val = read_ch_x();
int32_t y_val = read_ch_y();
if(touch_detect()){
x=x_val;
y=y_val;
return true;
}else return false;
return false;
TouchGFX
‎2020-04-16 11:29 AM
I talked to someone else here a while ago who had similar issues. So, there may be something wrong. I can tell you that nothing has changed in the math for the calibration matrix in years. I think we may have to investigate this issue at our end. The guy ended up implementing his own routines. If it seems like you can just offset y by 160 maybe just do that for now while i investigate this. I have a few resistive displays lying around.
/Martin
‎2020-04-16 10:09 PM
Hi @Martin KJELDSEN​ ,
Thanks for quick reply. Please let me know when you have any new information on this. For now I will just do as you said and continue with project.
‎2020-04-16 11:44 PM
Great, @Community member​,
Thanks for the feedback. Very helpful.
/Martin
‎2020-04-20 4:22 AM
@Martin KJELDSEN​
I used touch calibration routine by Carlos E. Vidales (source attached) and it's working like charm. As I seen in touchgfx source TouchCalibration.cpp (posted in link) Carlos E. Vidales routines with modifications are used. Perhaps there is some bug in modifications. Hope this helps in investigating this problem.
‎2020-04-20 4:30 AM
I think Carlos was the one i was thinking about. Thanks for reminding me!
/Martin
