Pasted items are arranged in inverted sequence and results in hidden items
‎2023-11-08 3:00 AM
Hi all,
I am working with TouchGFX Version 4.22.1 Designer.
When copying some items and paste them in another screen, the arrangement is inverted. Then e.g. a background rectangle covers a text element and therefore is not seen any longer.
I have to manually rearrange all items after copy/paste.
Is there a possibility to disable rearranging the pasted items?
This is a very nasty action as I often have to reuse a designed screen with a lot of overlayed items. Then I only have to change some items only. Rearranging then 20+ items is not a nice job...
Would be perfect to change this behavior so that rearranging is not necessary after the paste.
Thank you.
BR GS.
- Labels:
TouchGFX Designer
‎2023-11-10 3:37 AM
Hello @GS1 ,
Unfortunately, there are no options to disable the rearrangement. We will try to fix this issue, but for now there is a bit messy solution which is to open you TouchGFX project in a code editor like VS Code or Notepad++, and copy your items from there into to the screens you want. Every screen is a JSON so it would be easy to move items around.
I hope this helps you
‎2023-11-10 3:37 AM
Hello @GS1 ,
