Out of the box i cannot generate any project or compile simulator. I get this error and cannot understand a reason.
RSmir.1
Generate Code
   Generate
       Done
   Generate Assets
       make -f simulator/gcc/Makefile assets -j8
       The system cannot find the path specified.
       Converting images
       Reading ./application.config
       Failed
   Failed
AND FROM COMMAND LINE after make -f simulator/gcc/Makefile
Igenerated/texts/include -I../Middlewares/ST/touchgfx/framework/include -c gui/s
rc/easingequation_screen/EasingEquationGraph.cpp -o build/MINGW32_NT-6.2/gui/src
/easingequation_screen/EasingEquationGraph.o, ...) failed.
make (e=2): The system cannot find the file specified.
generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gu
i/src/easingequation_screen/EasingEquationGraph.o' failed
10 REPLIES 10
Alexandre RENOUX
Principal
Could you elaborate the steps you did ? What version of TouchGFX do you have ? If it's not 4.14, please upgrade to 4.14.
/Alexandre
RSmir.1
4.14.. It compiles in console but gives error in program. Looks like may be program does not change environment.. may be.. Steps: just load any demo and try to build simulator or generate code. It gives this...
Alexandre RENOUX
Principal
This should definitely be not the case. TouchGFX should work using out of box demos without any problem.
Can you try reinstall it ?
Could you provide sequentially the steps you did even if it sounds obvious ?
So it compiles but you cannot run the simulator nor on the board ? What do you mean by "program does not change environment" ?
/Alexandre
RSmir.1
Installed. Create new project for stm32. Open Imga example. Press Run Simulator. ANd get this:
Run Simulator
   Copy Framework
       Copying TouchGFX framework version 4.14.0 to C:\TouchGFXProjects\MyApplication\Middlewares\ST\touchgfx
       Done
   Generate
       Wrote config/gcc/app.mk
       Wrote config/msvs/Application.props
       Wrote generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp
       Wrote generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp
       Wrote generated/gui_generated/include/gui_generated/common/SimConstants.hpp
       Wrote generated/gui_generated/include/gui_generated/main_screen/MainViewBase.hpp
       Wrote generated/gui_generated/src/common/FrontendApplicationBase.cpp
       Wrote generated/gui_generated/src/main_screen/MainViewBase.cpp
       Wrote generated/simulator/gcc/Makefile
       Wrote generated/simulator/include/simulator/mainBase.hpp
       Wrote generated/simulator/msvs/touchgfx.props
       Wrote generated/simulator/msvs/touchgfx_prebuild.targets
       Wrote generated/simulator/msvs/touchgfx_sdl2.props
       Wrote generated/simulator/src/mainBase.cpp
       Wrote generated/simulator/touchgfx.ico
       Wrote generated/simulator/touchgfx.rc
       Wrote generated/simulator/touchgfx.res
       Wrote simulator/gcc/Makefile
       Wrote simulator/main.cpp
       Wrote simulator/msvs/Application.sln
       Wrote simulator/msvs/Application.vcxproj
       Wrote simulator/msvs/Application.vcxproj.filters
       Done
   Generate Assets
       Generating generated/images/src/image_ani_01.cpp
       Generating generated/images/src/image_ani_02.cpp
       Generating generated/images/src/image_ani_03.cpp
       Generating generated/images/src/image_ani_04.cpp
       Generating generated/images/src/image_ani_05.cpp
       Generating generated/images/src/image_ani_06.cpp
       Generating generated/images/src/image_ani_07.cpp
       Generating generated/images/src/image_ani_08.cpp
       Generating generated/images/src/image_ani_09.cpp
       Generating generated/images/src/image_ani_10.cpp
       Generating generated/images/src/image_ani_11.cpp
       Generating generated/images/src/image_ani_12.cpp
       Generating generated/images/src/image_ani_13.cpp
       Generating generated/images/src/image_ani_14.cpp
       Generating generated/images/src/image_bg.cpp
       Generating generated/images/src/image_btn.cpp
       Generating generated/images/src/image_btn_pressed.cpp
       Generating generated/images/include/BitmapDatabase.hpp
       Generating generated/images/src/BitmapDatabase.cpp
       Cleaning generated files from generated/texts and generated/fonts.
       Generating generated/fonts/src/GeneratedFont.cpp
       Generating generated/fonts/include/fonts/GeneratedFont.hpp
       Generating generated/fonts/include/fonts/CachedFont.hpp
       Generating generated/fonts/src/CachedFont.cpp
       Generating generated/fonts/include/fonts/FontCache.hpp
       Generating generated/fonts/src/FontCache.cpp
       Generating generated/fonts/src/ApplicationFontProvider.cpp
       Generating generated/fonts/include/fonts/ApplicationFontProvider.hpp
       Generating generated/texts/include/texts/TextKeysAndLanguages.hpp
       Generating generated/texts/include/texts/TypedTextDatabase.hpp
       Generating generated/texts/src/TypedTextDatabase.cpp
       Generating generated/texts/src/Texts.cpp
       Generating generated/texts/src/LanguageGb.cpp
       Failed
   Failed
Alexandre RENOUX
Principal
"Create new project for stm32. Open Imga example."
Create project where ? How ? What is lmga example ?
Unfortunately, what you gave me does not help trying to find out the issue. Try to be more precise.
/Alexandre
I genenerate project in TouchGFX from zero. Choose stm32 template and f.e Image Example project or any other. I do not use project generated by Cube MX or something. Just use Touch GFX. Project opens but when compiling it cannot find some assets. вт, 6 окт. 2020 г. в 05:08, ST Community :
What template ? Image Example does not exist but I suppose you are talking about the Animated Image Example.
Here are the steps I did and it worked :
  • Open TouchGFX 4.14
  • Select F746-DISCO Application Template v3.0.1
  • Select Animated Image Example as UI template
  • Create project
  • Clikc Run Simulator Button
  • Everything is generated correctly, compiles and simulator is launched
I need more information to understand your problem. But first try to reinstall TouchGFX and do the steps I did.
/Alexandre
I tried to figure out myself... Paths are ok. I only have this output from compiler - something about missing assets... ok.. anyway it compiles from console.... i reinstalled program and have the same output... Don`t know how to diagnose more. Look at compiler output in previous messages. �?р, 7 окт. 2020 г. в 04:22, ST Community :
RSmir.1
HOW TO UNDERSTAND WHAT IS MISSING?? all folders in generated project are in place. Should be there some path included in environment variables??
Generate Assets
       Failed
   Failed
