LTDC Color Order
RShan
I'm trying to find a way to change the color order of the LTDC for RGB565. It apears that the link between the memory and the LTDC pins is fixed. I would like to output in order BGR instead of RGB. Nothing stand out in the reference manual (STM32F468) to me. Any ideas or pointers?
Kind Regards,
Rob
Hi
The color order manipulated by the higher layer drivers.
In case you use STEmWin, the default conf is BGR
by defining this #define GUI_USE_ARGB (1) inside GUIConf.h can change the mode to RGB
RShan
Thanks for the tip Vangelis !
