insert() instead of add() to insert a button as Z-order
COSEBE
Why is it not possible to insert a button instead of adding this button with add() ?
I need to place it in a specific Z position
Martin KJELDSEN
Chief III
It just isn't :)
You can roll your own by calling remove(), add()-ing where you want to, then re-add() the ones you removed.
/Martin
