I'm using STM32F413H-Discovery board and having issue with mounted on-board touchscreen. I loaded example project BSP into the board but TS Demo 1, TS Demo 2, TS Demo 3 did not show output as expected. Please advise on how to solve this issue. Thanks.
2022-10-04 8:07 PM
2022-10-05 3:18 AM
Hi @Community member and welcome to the Community :),
If you used the STM32F413H_Discovery_REVE board, please make sure to select the target board revision in the project options as mentioned in the stm32f413h_discovery.h.
Kaouthar
2022-10-05 8:50 PM
Hi @KDJEM.1 / Kaouthar,
Thank you for your reply.
I used STM32F413H-DISCO MB1274-F413ZHT6-E03.
I tried defined flag USE_STM32F413H_DISCOVERY_REVE in line 87 in the stm32f413h_discovery.h file but result shows same error.
Is there any other possible solution?
Thanks again.
2022-10-12 6:09 AM
Hi @Community member,
I confirm the issue: the STM32F413H-DISCO-REVE03 is not supported for BSP example.
In fact, the FRD154BP2902-D-CTQ LCD should use the BSP component ft3x67.
I reported this issue internally.
Internal ticket number: 136410 (This is an internal tracking number and is not accessible or usable by customers).
Thank you
Kaouthar
2022-10-13 7:39 PM
Hi @KDJEM.1 ,
Is there any other example project that I can use to calibrate and test my touch panel for STM32F413H-DISCO-REVE03 board? or any example project with minor modification?
Thanks.
