I have a X-NUCLEO-GFX02Z1 that I would like to use with a NUCLEO-U575ZI-Q. Is there any application code available to drive the display? Seems like there would be, but I haven't located it.
Pat1
4 REPLIES 4
X-CUBE-DISPLAY_2_0_1\Projects\NUCLEO-U575ZI-Q\Applications\GFX02Z1_HelloWorld
X-CUBE-DISPLAY_2_0_1\Drivers\BSP\Components\ili9341\ili9341.c
X-CUBE-DISPLAY_2_0_1\Drivers\BSP\Components\mx25l6433f\ospi\mx25l6433f.c
https://www.st.com/en/embedded-software/x-cube-display.html @Amel NASRI​ @Imen DAHMEN​ 2.1.0 goes to page not found link, will try the email request next. Emailed link works, webpage/login one does not.
Hi @Community member​ ,
I didn't catch the issue you are facing. Could you please re-explain when it appears exactly?
-Amel
Attempting to download X Cube Display 2.1.0 as a logged in user resulted in a redirection to a page not found screen.​
OK I see. No such issue on my side. I reported this internally for farther check. I'll keep you informed.
One more question: is issue faced only for X-Cube-Display or for all packages download?
-Amel
