I am working with a STM32H745I-DISCO, but there are not an "Application Template" for it in the TouchCFX designer. Are there plans for supporting an "Application Template" for STM32H745I-DISCO in the near future ? Regards Flemming
FJahn.1
Alexandre RENOUX
Principal
Hello FJahn.1,
Yes there are plans for having an Application template for H747-DISCO and EVAL (very similar to H745) compatible with CubeMX and TouchGFX Generator.
Unfortunately I cannot give you any date for now. But it should be possible to have before the end of Q1 2021 but again nothing sure on that side.
I believe you can use the Application Template for H747-DSICO as a reference and adapt it to your H745-DISCO. But you will not be able to use CubeMX like you want to. Most of it will be manual porting.
Sorry for the inconvenience,
/Alexandre
