2025-09-19 5:19 AM
My project is working as expected using the DSI_TE_EXTERNAL with a TE pin from the display.
How to get the TE event via DSI? Is that default enabled?
If I use "CmdCfg.AutomaticRefresh = DSI_AR_ENABLE;" then I get the interrupt to my callback. But timing is bad.
Anyone solved the problem earlier?
2025-09-21 11:10 PM
How to use STM32L4R9-DISCO with CmdCfg.TearingEffectSource = DSI_TE_DSILINK ??
That could be first step to see the settings in my setup.
2025-10-15 10:11 AM
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Christian
