How to propagate a flex button callback from a container inside another container to current view?
AL
I put a group of same small custom containers inside a large container. Then I added this large container to my view. How can I propagate button callback from small container to current view and also identify which small container triggers the callback?
Alexandre RENOUX
Principal
Hello AL,
You do it like you would normally propagate a callback from a widget to the view.
The difference is that you create a callback in your container that triggers a callback in your bigger container that triggers a callback in your view and calls the callback handler.
/Alexandre
Alexandre RENOUX
Principal
Hello AL,
/Alexandre
Thank you.
