how to display the value in float using snprintf?
Angle
Hi, how can i use the snprintf for float value in touchgfx? I want to display the data from the sensor in touchgfx lcd but in float
12 REPLIES 12
Have you checked if the "update" functions are called when needed and that the angle_pitch/... values are correct as well when debugging ? I would guess that those angle values are never updated if everything else is working fine on the screen.
/Romain
is okay I got it already
What do you mean ?
