2020-11-05 2:08 AM
Hi ST,
I am doing a project:
Thank you.
2020-11-18 1:17 AM
This is a very broad question. For your second point: Check out the DSI application templates from TouchGFX designer. The TouchGFX Generator in CubeMX only supports LTDC and custom display interface (LTDC = you get the driver for free, custom = you have to write it yourself).
For the first point: Not entirely sure what you mean here. But generally, a screen is rendered to the framebuffer (maybe SDRAM), and transferred to the display from here.
/Martin
2020-11-18 1:17 AM
/Martin
