How do I configure the peripherals required for TouchGFX using CubeMX 5.0.0?
When I use CubeMX 5.0.0 to configure a TouchGFX project, CubeMX appears to configure the peripherals correctly if I select "Yes" when CubeMX asks "Initialize all peripherals with their default mode". However I do not want to do this as it initializes too many peripherals.
If I select "No" I have not been able to figure out how to configure the peripherals to enable Graphics. I have noticed that there is a very brief summary when I hover my mouse over Graphics but this does not provide sufficient help.
Could you provide guidance on how to properly configure the required peripherals?
Thank you for providing CubeMX and for purchasing the best GUI software...TouchGFX.
