Hey ive been wondering using this environment is it possible to make your own source files where you would have all the programs code and then just stab them into the MVP structure from the sources. That way my projects would stay far less messy imo.
SLind.3
Alexandre RENOUX
Principal
I believe you can indeed have all your code in your own files and link them to the TouchGFX framework accordingly following the MVP structure.
But you might need to elaborate more for a more precise answer.
/Alexandre
