2025-08-25 6:32 AM
When I create new text in TouchGFX Designer and upload program into internal storage, it does not render on the display. I use STM32H563ZIT6(my own custom board, not the nucleo kit) with no external loader. Everything works fine and I can also upload images which work correctly. It seems that font glyphs(or something else idk) are not being uploaded to internal storage. Fonts are compiling correctly, there are cpp files in folders they should be in. I tried debugging and searching for glyphs in Memory, but did not find anything.
I would also be glad for some tips how to upload data to the different storages like FRAM and NAND Flash.
I already used FRAM, but do not have any experiences how to set communication between FRAM, NAND Flash and internal cpu storage. Maybe it will be better to load the whole program into NAND FLASH??
Thank you.
Martin
