2021-06-02 10:29 AM
Repro steps (using TouchGFX Designer 4.16.1):
#include <gui_generated/containers/BackgroundBase.hpp>I realize TouchGFX Designer is windows-OS centric and that is case-insensitive, but the code it generates is often used in case-sensitive environments.
2021-06-03 12:09 AM
I am a bit confused by this as the generated file names are properly updated in my case, or maybe I do not understand properly the steps you shared. Could you share a project where you face this ?
/Romain
2021-06-03 5:52 AM
