Changing template after creation of the project
GMeur
Senior II
Is it possible to change the template of a projet after its creation ?
Thanks.
Martin KJELDSEN
Chief III
Hi @GMeur​,
In a way, but there isn't a direct "conversion" feature. What you can do is this:
  • Create a new application based on the right template (empty UI)
  • Import the UI of your old application that used the wrong template
  • Your new application has the right UI and the right Appliacation template. Delete the old application.
Hope that helps.
Best regards,
Martin
Martin KJELDSEN
Chief III
Hi @GMeur​,
Hope that helps.
Best regards,
Martin
