caching use dma?
Ezgi
Is caching using DMA while the bitmap is caching in Touchgfx?
No, DMA isn't a storage space (of any significant size), so it's not using that.
Looks like it's using SDRAM in this example. Probably uses whatever memory you have set up.
https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/caching-bitmaps
6 REPLIES 6
waclawek.jan
You mean the data/instruction cache on AXI in 'F7?
It reads/writes portions of memory autonomously, but it's not the same as what the DMA units do. These reads/writes are completely transparent to the user, no need to configure/start them.
I'm actually asking what is used when caching the bitmap.
waclawek.jan
Where? What bitmap?
In Touchgfx, I want a bitmap to cache. How does caching read the bitmap and write?
scottSD
Lead
Are you talking about a dynamic bitmap? Your question is not very clear.
