STM32L15xx microcontroller can internal FLASH Read Protection be enabled inside flashed SW?
2023-03-01 4:21 AM
My project is based on STM32L15xx microcontroller. I know, that internal FLASH Read Protection may be enabled during programming an image by STMFlashLoader with --erp option. My question is: can I compile my image with internal FLASH read protection enabled by some tweak so that I don't have to use "--erp" option on downloading my image to the target?
Thanks in advance!
Flash
RDP
STM32L1 Series
2023-03-01 6:24 AM
Hello @DLyum.1 ,
You need to Unlock the Flash and OB to enable the flash control register access.
Here is an example:
FLASH_OBProgramInitTypeDef obProgram = { 0 };
obProgram.OPTIONBYTE_RDP = OB_RDP_LEVEL_1;
FLASH_OB_RDPConfig
HAL_FLASHEx_OBGetConfig(&obProgram);
if (obProgram.RDPLevel == OB_RDP_LEVEL_1)
The function FLASH_OB_RDPConfig(); could be used.
Hope this helps!
2023-03-01 5:42 AM
Should be able to check the state of the option bytes, and change them.
2023-03-01 6:02 AM
Thank you!
The Option Bytes are described in PM0062 (Flash and EEPROM Programming Manual) application notes.
2023-03-01 6:24 AM
Hello @DLyum.1 ,
Here is an example:
FLASH_OB_RDPConfig
Hope this helps!
2023-03-01 6:32 AM
Thank you!
