2021-06-08 10:12 AM
In the video, "Security Part6 - STM32 security ecosystem - 02 Building the SBSFU" there are some scripts under the folder "STM32SecuWS" which are unavailable in the SBSFU download software. Where can I get these scripts? I am also struggling while following the U2262 manual in step 8. The welcome screen does not display after I configure TeraTerm. I am not sure if I did the flashing thing wrong- it is a bit unclear. Would appreciate any help thanks.
2021-06-10 12:25 AM
Hello, these are not part of the SBSFU, these are specific to this course. Under the video is a link to web page that contains the course materials:
https://drive.google.com/drive/folders/18AetVN1BpxSz1GdH3sN6-Kgl6JH-_lUo?usp=sharing
2021-06-09 5:52 AM
Hi @APara.5 ,
can you be more specific?
What minute in the video are the scripts launched or what is the filename?
Even if the TeraTerm is not connected, the onboard LED will be flashing when the code is executed. That's how you know the board works and you only need to work on the connection. Try unplugging the Nucleo and connecting it back again.
Jarda
2021-06-09 8:52 AM
minute 11 theres a bunch of scripts to launch in Tera Term. I tried unplugging and plugging several times. my board does flash, but I don't get the welcome screen. not sure where to proceed from there
2021-06-10 12:25 AM
