2022-11-29 07:54 AM
Hello STM32U5 community,
I was making a few attemps with my B-U585I-IOT02A demo board and TF-M. I am afraid I have irreversibly locked the MCU.
Here is what I did:
Now I fail to reconnect with the MCU by any means. What can I do? TZEN/RDP regression with boot from RSS? AN5347 says "a small rework" must be done. I would appreciate a step by step instruction.
Regards.
2022-11-29 08:43 AM
Hi @ELuca.2
To solve the issue you need to:
You need to Switch the RDP value to Level 0 and Uncheck the TZEN value before programming the option bytes, otherwise it won't work.
Best Regards,
A.MVE
2022-11-29 08:43 AM
Hi @ELuca.2
Best Regards,
A.MVE
2022-11-29 09:11 AM
Thanks A. MVE.
It worked! I was a bit confused because CubeProgrammer raised some reading error messages at connection time. But apparently it was still able to change RDP/TZEN.
2022-11-30 12:32 AM
Hi @ELuca.2 ,
I am glad to heard it .
To let the others STM32U5's users find the thread, select the answer as best.
Best Regards,
A.MVE
