Why there is no burst write option available for muxed NOR FSMC configuration?
Pranay Dhuri
Posted on April 27, 2017 at 09:18
I am configuring fsmc using CubeMX, while configuring i found that  burst read option is not available for configuration.
cant we configure NOR fsmc for burst read write mode?
Imen.D
Posted on June 05, 2017 at 15:14
Hi
Dhuri.Pranay
You may review the errata sheet related to your deviceto check if you have the same conditions as described in the errata sheet.
Imen
Imen
