Why the number of data I sent is wrong when using HAL_SPI_TransmitReceive() ?
Options
2020-10-29 4:04 AM
HAL_SPI_TransmitReceive(&hspi1,tx_sensor_data,rx_sensor_data,8,0);
I want sent 8bytes, but only 2bytes sent, why?
Labels:
- Labels:
SPI
Options
2020-11-11 1:35 AM
I solved it. The general set is wrong. Must set 8 bits not 4bits or 2bits
2 REPLIES 2
Options
2020-10-29 4:49 AM
You have a timeout of 0, which may be the issue. If you want it to be blocking, use HAL_MAX_DELAY.
Options
2020-11-11 1:35 AM
