Why Fast_Read need a Dummy Byte?
495567585
Posted on August 23, 2011 at 02:50
hi!
While reading flash or some other in Fast_Read mode, we have to send a DUMMY Byte in order to receive Results?
Why it is required?
I'm waiting for your reply...
Posted on August 23, 2011 at 03:08
You need to provide far more context and details for your question to make sense to the general forum audience unfamiliar with your project, or the code and libraries being used.
Assuming for a second that this is an SPI interfaced device, you have to send data in order to generate the clock pulses, and in turn capture data returned from the device.
