when I call tick I get HardFault
Eblec.1
when I call tick I get HardFault. what can be the problem ? thanks.
4 REPLIES 4
Javier1
Principal
are you "calling tick" inside an interruption?
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
Eblec.1
I'll check it. thanks.
Need more info here. What does "call tick" mean? What do the SCB registers indicate as the source of the hard fault?
Unpack what's actually faulting the processor and look at that code.
Perhaps uninitialized pointer/structures.
A while(1) in the Hard Fault Handler will tell you very little.
