2021-08-09 4:02 PM
I am referring to the regulator connected to the usb 5V ( the 5V pin), can it handle a voltage of 12v and step it down to 3.3V for the chip? if not then what is the limit?
2021-08-09 4:56 PM
Check the schematic and placed components on the board you have
RT9193-33 looks to max out at 5.5V
https://www.richtek.com/assets/product_file/RT9193/DS9193-16.pdf
2021-08-09 4:56 PM
2021-08-10 3:09 AM
Bluepill is produced by many asian companies. Parts used may differ, but assuming 5.5 V max is a good guess.
