WFI problem
Options
‎2009-06-25 11:54 AM
Posted on June 25, 2009 at 20:54
WFI problem
11 REPLIES 11
Options
‎2011-05-17 04:13 AM
Posted on May 17, 2011 at 13:13
Spot on Andreas.
NVIC_GenerateSystemReset() did the trick. It is now functioning as I intended. Thanks very much. Can you tell me where this function is documented with this level of detail? The ST FWLib document just tells you that the function exists and a one line example of its use. Cheers AdrianOptions
Glad it helped.
The Cortex behavior is from ARM documentation. The firmware library calls are ''documented'' in the form of the C source code they're shipped as... :p I find the FWLib docs largely useless, it looks more like an auto-generated list of functions (and I get more or less the same info from ctrl-space in Eclipse). I usually have to match the source code to the register descriptions in the ref manual to see what a function actually does.
- « Previous
- 1
- 2
- Next »
