USB response getting slow after a long run
Anantha Raman
Posted on December 28, 2016 at 05:23
I am using STMF427 mcu. We have used the USB CDC library to have usb logging enabled. The issue I am facing is really weird. I have a console based application to set all the required serial number, model number etc. When my testers are doing the settings through a script for 100 times after some number of loops I see that command response becomes very slow.
For eg:
I enter the command get_serial_num I wont get the response now but when I give the next command get_model_num I get the response for the previous command.
0 REPLIES 0
