USB is not getting detected
Options
‎2010-10-06 12:22 AM
Posted on October 06, 2010 at 09:22
7 REPLIES 7
Options
‎2011-05-17 5:10 AM
Posted on May 17, 2011 at 14:10 Make sure you have the pullup on the data pins turned on (depending on USB speed, this will be on different lines).
Options
‎2011-05-17 5:10 AM
If you mean no detection at all, try the resistor but once it is detected but not recognized, please have a look on the USB PLL clock. RegardsOptions
‎2011-05-17 5:10 AM
Options
‎2011-05-17 5:10 AM
Posted on May 17, 2011 at 14:10you need pull up on your D+ line
Options
‎2011-05-17 5:10 AM
Posted on May 17, 2011 at 14:10I connected the pull up resistor of 1.5k from D+ to VSSA. I got a warning msg ''One of the USB devices attached to this computer has malfunctioned and windows does not recognise it''
Options
‎2011-05-17 5:10 AM
Posted on May 17, 2011 at 14:10I tried it but still i am getting the same error. Any other suggestions..? please
Options
‎2011-05-17 5:10 AM
Posted on May 17, 2011 at 14:10 VSSA is Analog Ground. It need 3.3V for a pullup. You should connect it to a GPIO pin that you can toggle.
