USART Rx problem
opiol
Posted on February 13, 2012 at 20:16
I have a little problem with Rx on stm32f417.
I designed my own board, byt i am putting this here, becouse i cannot find another approperiate forum.
I tried to set up UART2, but i cannot make reciving working.
HW is OK, i tested that.
void USART_Inicializace(void)
GPIO_InitTypeDef GPIO_InitStructure2;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);  // 1.
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE); // 2.
GPIO_PinAFConfig  ( GPIOD, GPIO_PinSource5 , GPIO_AF_USART2) ;
GPIO_PinAFConfig  ( GPIOD, GPIO_PinSource6 , GPIO_AF_USART2) ;
//   //  Tx
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; // alternate function!
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP ;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
//   // Rx
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART2, &USART_InitStructure);
USART_Cmd(USART2, ENABLE);
// jeste zbyva konfigurace preruseni
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
//   NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
//   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
//   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
//   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//   NVIC_Init(&NVIC_InitStructure);
// USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
Thank you.
13 REPLIES 13
jean_prieur
Posted on April 24, 2013 at 12:57
I think I highlighted the problem... I try my code with IAR (because I'm on
Coocox, ARM toolchain) and it works !
It's seems that with Coocox, my MIDI frames are sent with the wrong baudrate
(because on the scope I can see the datarate is slower than the MIDI from my
synth).
I don't know what to do, because in IAR and in Coocox I have the same code and the same
system_stm32f4xx.c...
Posted on April 24, 2013 at 13:30
Check the project's meta data for defines sent to the compilers command line, HSE_VALUE being a primary culprit for mismatched baud rates. Check also the PLL settings correlate with the crystal on your board.
jean_prieur
Posted on April 24, 2013 at 13:46
I just check with a scope, my STM32 is working at 8MHz !! (Instead of 144Mhz)
Do you know how can check the project's meta data ? I'm not familiar with this...
Posted on April 24, 2013 at 15:10
It's all the stuff under the ''Options'' for a project, probably the C/C++ tabs or whatever the equivalent is in IAR vs CooCox.
Where the project files are ASCII text (ie XML, etc) you can also comb through them, or makefiles if the tools can generate those.
