Turning off both TIMx complementary PWM outputs with Break feature
bolurian
Does any body have sample code on how to configure TIM1 to set both complimentary outputs low and latched off when a comparator if configured to trigger the break feature?
If no example code, then may be the proper TIMx register setting?
I may have MOE set or not set in my code. Thank you!
0 REPLIES 0
