timer15 update interrupt
Options
‎2013-08-22 7:11 AM
Posted on August 22, 2013 at 16:11
hi,
i'm using an f3 disco board and i want to configure its timer 15 with an update interrupt. i want it to be interrupted every one second to toggle two on-board LEDs. following is the code for timer15 and NVIC configuration.void
Init_TIM15()
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
int
Prescaler_Val = (SystemCoreClock/2000)-1;
STM_EVAL_LEDInit(LED3);
STM_EVAL_LEDInit(LED4);
STM_EVAL_LEDOff(LED3);
STM_EVAL_LEDOn(LED4);
RCC_APB2PeriphResetCmd(RCC_APB2Periph_TIM15, ENABLE);
/* Enable the TIM15 gloabal Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM1_BRK_TIM15_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
TIM_TimeBaseStructInit(&TIM_TimeBaseInitStructure);
TIM_TimeBaseInitStructure.TIM_Period = 2000;
TIM_TimeBaseInitStructure.TIM_Prescaler = 0;
TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM15, &TIM_TimeBaseInitStructure);
TIM_PrescalerConfig(TIM15, Prescaler_Val, TIM_PSCReloadMode_Immediate);
TIM_ITConfig(TIM15, TIM_IT_Update, ENABLE);
TIM_Cmd(TIM15, ENABLE);
int
main(
void
int
count = 0;
Init_TIM15();
while
(1){
count = TIM_GetCounter(TIM15);
and here is the code i placed insidestm32f30x_it.c file.
void
TIM1_BRK_TIM15_IRQHandler(
void
if
(TIM_GetITStatus(TIM15, TIM_IT_Update) != RESET){
TIM_ClearITPendingBit(TIM15, TIM_IT_Update);
STM_EVAL_LEDToggle(LED3);
STM_EVAL_LEDToggle(LED4);
when i run it, the LEDs stays in initial states and never toggles. in the main function, i updated a variable (count) continuously with the timer's count value and watched it under debug mode and it says that the value of the count is not in scope.
can someone please tell me if i'm making any mistakes with above codes??
thanks in advance!
Options
‎2013-08-22 8:04 AM
Posted on August 22, 2013 at 17:04
Clock NOT Reset
Options
‎2013-08-22 8:06 AM
Posted on August 22, 2013 at 17:06
void Init_TIM15()
int Prescaler_Val = (SystemCoreClock/2000)-1;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM15, ENABLE);
TIM_TimeBaseInitStructure.TIM_Prescaler = Prescaler_Val;
TIM_TimeBaseInitStructure.TIM_Period = 2000 - 1;
int main(void)
int count = 0;
Init_TIM15();
while(1){
Options
‎2013-08-22 9:25 AM
Posted on August 22, 2013 at 18:25
thank you very much! it worked.:)
