Timer update event interrupt retriggering after exit.
mark_verheyen
Posted on January 21, 2011 at 20:18
13 REPLIES 13
mark_verheyen
Posted on May 17, 2011 at 14:22
Great!  Thank you for the thorough explanation.  Would it be possible to put this level of detail in the technical manual?
Mark
Nickname13914_O
Hi Mark,
I just found a similar explanation in the FAQ.
/FAQ/Lists/faqlist/DispForm.aspx?ID=144
etienne2
Posted on July 02, 2014 at 11:19
The relevant faq entry has been moved:
https://my.st.com/public/Faq/Lists/faqlst/DispForm.aspx?ID=143
Posted on July 02, 2014 at 13:26
As a clickable link
I'll note that the suggestion to use bit-banding is probably a bad one, and particularly dangerous for TIMx->SR cases as it's only atomic from the processors perspective. It can result in dismissing interrupts that pend in the 4 or whatever cycles between the read/write
