timer 2 and its channel
Posted on August 20, 2013 at 16:57
I am working for 6 months with the Timer 2 of a STM32L15x.I use the channel 2 to capture the timer value; The pin used is PB3.My application is working fine.Now, for an hardware problematic, I need to use the channel 3. So I mapped channel 3 and PB10. Now the application is working, but some values are not accurate.I understand that my problem is not very understanding;But I would like to know if you have already work with the timer 2 and channel 2 and 3, and if the expected results are ok?thank you very much. #timer2-channel-accuracy
