aeolia_amha
TIM repetition counter
  • May 21, 2010
  • 1 reply
  • 820 views
Posted on May 21, 2010 at 07:05
    1 reply
    lowpowermcu
    Posted on May 17, 2011 at 13:51
    Hi benison,
    For example in upcounting mode:
    if the repetition counter is equal to 0, the update event is generated at each overflow.
    if repetition counter is equal to 1, the update event is generated at each 2 consecutive overflows.
    if repetition counter is equal to 255, the update event is generated at each 256 consecutive overflows.
    That's what I have understood when I have used this feature. Thanks to correct me if you find something else.
    You can find in the reference manual a figure that explains this. Refer to
    ''Update rate examples depending on mode and TIMx_RCR register
    settings'' (or something like this).
    MCU Lüfter,
    be low power
