The Microcontroller programs but it's not working!
‎2017-02-27 6:46 AM
Dear Friends,
I have designed two identical PCB boards and I used stm32f103rbt6 microcontroller.
One of them works properly but the other one has a problem which I cannot understand.
The micro programs successfully but it is not working!!!!
I have checked every traces and ICs on the PCB board and there in no problem.
I wonder if you could help me in finding the problem.
Is it possible while soldering, micro find some problems?
(Both micros have the same program.)
‎2017-02-27 7:05 AM
Misplaced or wrong components ?
A cold solder joint ?
Supply voltages o.k. ?
After checking that, I would try to debug the board.
‎2017-02-27 7:32 AM
I have checked the supply voltage and components. There is no problem.
But during soldering, the micro became a little bit warm and I doubt if that harmed micro, would it still done programming?(since when I download my codes in the micro using st link v2 in SWD mode, it finishes programming.)
‎2017-02-27 8:59 AM
You'll need to utilize a debugger and diagnostic skills to refine 'doesn't work' into some specific causal reason.
Make sure the BOOT0 pin is pulled LOW
‎2017-02-27 10:01 AM
When I wanted to check the micro, I set one of its pins and I used a voltmeter to see if it's high or not and it was around 2v which is considered to be low!
And the BOOT0 pin is pulled low using a 10kohms resistor.
I think i must change the micro.
‎2017-02-27 11:42 AM
It actually matters which pin. And 2Volt is not 'low', but rather logically undefined/illegal. Most probably in high-Z mode.
Attach a debugger, and see if you can step into the reset handler.
‎2017-02-27 11:52 AM
That is one course of action, two boards isn't really a good statistical sample.
‎2017-02-28 12:11 AM
And, this course of action does not give you any insight what was/is wrong with that second one.
There is a good chance of repeating this story with the next batch of boards ...
