The CubeMX Tool isn't working with MAC
Rob Ashworth
Posted on June 15, 2018 at 08:14
The CubeMX, and associated Flash programming tool doesn't want to install with the latest version of OSX (High Sierra).  Is this a known issue or am I doing something wrong...?
john doe
Lead
Posted on July 04, 2018 at 14:31
open a terminal window and execute the following command
sudo xattr -r -d com.apple.quarantine
<whatever the path to your installer is>
st chooses not to sign their installer
4 REPLIES 4
Nawres GHARBI
Posted on July 04, 2018 at 11:41
Hi
robdashworth
Could you please precise your java version
Posted on July 04, 2018 at 11:54
JAVA version is Version 8 Update 171
Thanks,
Rob
john doe
Lead
Posted on July 04, 2018 at 16:13
Hi John/Nawres,
Thanks, that seems to have worked - all installed anyway.
Rob
