SW4STM32 + STM3210C-Eval Hello World program
John Osen
Posted on February 03, 2017 at 21:58
I am evaluating an STM32 chip with CAN with respect to the CAN enabled bootloader.
I have programmed for years on the TI CCS IDE on ARM4s.  SW4STM32 is a similar IDE.
I have SW4STM32 installed.  I have the STM3210C connected via USB.
I get the following when trying to debug:
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
localhost:3333: The system tried to join a drive to a directory on a joined drive.
I am trying to get to the point where I can set a breakpoint on the first statement in main().
I have attached screen shots of my debug configuration settings, where I would guess my settings are not correct.
Might someone suggest what I have amiss?
Where may I find some SW4STM32 quickstart documentation?  Especially for the STM3210C-EVAL?
Posted on March 23, 2017 at 13:36
I apologize for not closing this thread earlier.  It turns out the sales rep did not give me the necessary emulator.  I assumed the emulator was embedded on the eval board.  It was not.  Once that significant issue was resolved, I was emulating in minutes.
Oliver Beirne
Posted on February 04, 2017 at 09:35
Hello John
I have moved your thread to the
https://community.st.com/community/stm32-community/stm32-forum?sr=search&searchId=632a6e8e-67ed-4a19-8d03-8db68dd30c42&searchIndex=0
‌ where someone should be able to assist you.
Oli
Imen.D
Posted on March 22, 2017 at 15:59
I think that this error is due to the pending debug session and may be you
 have many active gdb instances
So,
you need to close them from debug perspective (
Window > Open Perspective > Other >Debug
), then from 'Debug view' you should terminate/remove all active sessions and be sure
that all debug session are off.
You would refer to the
http://www.ac6-tools.com/content.php/content_SW4MCU//lang_en_GB.xphp
Imen
Imen
