suggestions for 2 MSPS ADC on 2 channels, DSP processing and results to PC or R-PI
Mario Cannistrà
Posted on November 09, 2016 at 18:02
Hi all.
I'm new to this platform, checking if I could use it in this scenario.
Which kit / evaluation module / board would you suggest in order to test/evaluate this build:
1) acquire 2 analog values on separate channels at fast rate (> 2 MSPS) , minimum 12 bit for each value, better if higher
2) optionally perform some DSP processing (is FFT on a data buffer available?)
3) send raw data or FFT results to Raspberry PI or PC via another fast interface, could be USB high speed
Thank you,
Mario
#adc #stm32
slimen
Posted on November 17, 2016 at 17:00
Welcome to the Community.
Regarding the way to start in order to choose your hardware, you have various choices, it depends on your needs, preferences and what software/IDE to use.
You can refer to this
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-dspdemo.html
for the software download and the
http://www.st.com/content/ccc/resource/technical/document/application_note/group0/c1/ee/18/7a/f9/45/45/3b/DM00273990/files/DM002739pdf/jcr:content/translations/en.DM002739pdf
Application note Digital signal processing for STM32 microcontrollers using CMSIS.
You can have a look to the provided CMSIS/DSP_Lib examples for STM32CubeF4 available inSTM32Cube_FW_F4_V1.0\Drivers\CMSIS\DSP_Lib\Examples
There is the DSP library containing example programs for FFT.
Also, I found this
http://stm32f4-discovery.com/2014/10/stm32f4-fft-example/
and this
https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=https%3a//my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/FFT%20in%20STM32F0&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=4839
, it maybe helpful for you.
Hope this helps you.
Mario Cannistrà
Posted on November 18, 2016 at 16:58
Hello forumstm32.
Thank you for your kind answer.
I will go through the tutorial and the sample code and give you feedback asap.
About my needs: i would need to process IQ data in a SDR scenario.
I can adapt to the necessary IDE after choosing the HW.
Kind regards,
Mario
