structures
ASSAAD.ASSAAD
Hello All , I am sorry it might be the wrong forum ,
i use STM32f429 with TFT to create a menu system
I am declare a structures for menu but i dont have success to put a structure in side a struture
could me what is wrong ?
 struct menu_type
char  *title;
unsigned char type;
uint16_t  rec_xpos;
uint16_t  rec_ypos;
uint16_t  rec_width;
uint16_t  rec_high;
unsigned int num_items ;
char* items [ 100] ;
void (*nag_ok)();
void (*nag_right)();
void (*nag_left)();
void (*command)();
struct menu_main
struct menu_type submenus;
how can I pass the variables to menu_main ?
Thank you all
Yes, this is definitely the wrong forum. I'd suggest an introduction-to-C-programming forum to learn the basics of the language.
Not even sure what the question is actually asking.
How do you initialize said structure? Is that what you're asking?
Or how to assign values?
foo.submenus.title = "Some Title";
I prefer to use "typedef struct _xyz {} xyz;" form.
